total timing questions
Old Oct 23, 2001 | 11:44 PM
speedlvr's Avatar
Ok, initial + vacuum + centrifugal advance = total advance timing.
What should the highest total be?
This figure does not stay constant does it?
As long as detonation does not occur, you are within safe timing limits. True or false?
Can there be detonation that you can't hear?
Thank you.
Old Oct 24, 2001 | 09:38 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That would be the total on cruise/part throttle driving.
But generally when timing is spoken of in terms of "xx*'s, all in by xxxxRPMs", you're only looking at what the distributor's mechanical advance is capable of.
At WOT, there is no vacuum advance, the only advance the ignition is giving is from the centrifugal action of the distributor throwing the weights out.
I'd guess that maybe about 45*'s is the most you'd see.
Old Oct 24, 2001 | 09:50 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
<font face="Verdana, Arial" size="2">Originally posted by speedlvr:
</font>
What ever you can get away with that will not cause the detonation and will not cause NOX emission to go through the roof
</font>
Nope
</font>
Yep, depends on what type of exhaust you have and how good your ear is.
It rarely happens at steady speeds. Listen at very light acceleration and full throttle mostly. Each is a reflection of a different thing going on inside the motor (and can be addressed by changing the relationship between motor and research octane, if you have the ability to make such a change).
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
