Vortec-Fastburn-E-Tec Guys, what is your total ignition timing?
Old Sep 6, 2005 | 02:48 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just want to see where everyone with "fast burning" heads has there timing set, and with what compression ratio.
I change mine all the time and I cannot decide which is better 34 or 36.
Old Sep 6, 2005 | 03:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you might find it likes 32 or even as low as 28.. best way to tell is at the dragstrip...
Old Sep 7, 2005 | 03:17 PM
Russ-So Cal's Avatar
MrDude1 is right. Fast burn head technology is designed to make the mixture burn faster. Timing advance is designed to fire the plugs at just the right time to make the peak combustion pressure at the precise moment needed for max power. Fast burn requires less timing.
Old Sep 7, 2005 | 10:45 PM
GASGZLR's Avatar
I know that fast burn needs less timing than usual, but when I had my etec 355 it ran best with 36 total timing on the dyno. However it made more low end torque with 34 total. All these magazine articles range their timing from 32-36 with Vortec style heads. I guess I will just have to go get it dynoed with the stroker.
BRoss99
Aug 10, 2025 05:08 PM
customblackbird
Aug 15, 2021 10:16 PM
bellez77
Sep 5, 2015 08:39 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
