Plastic burning on exhaust manifolds!
Old Oct 24, 2001 | 08:13 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Well,
I have an 86 IROC w/305 and one of the many black plastic coil thingys that hold wires in them got on top of my driver side exhaust manifold, well needless to say I got a melted piece about the size of a quarter of that plasitc stuff on it and it is burning everytime the engine hits above I'd say 160* degrees. Problem is I cant see it anymore, so where would it 'run to'?? Would I be able to get under the car and see it?? Or could an ignition wire going to one of the 8 plugs that is cut a little cause this burning smell?? I am asking only because It happened like a month ago and has NOT gone away and both happened at the same time!
PLEASE HELP IT IS annoying me ALOT!
Old Oct 24, 2001 | 08:15 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have had the same plastick melt on the headers, I don't smell anything that is burning. You said that one your plug wires has a cut in it. If read that right, you need to replace that wire as it is most likely causing your car to have a miss.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 24, 2001 | 08:17 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Would the cut plug cause the smell though?? (Just want to know?)
Old Oct 24, 2001 | 08:32 PM
Xenodrgn's Avatar
Chances are, whatever was burning, still is...
I had a wire burn on my headers, all I did was move it (and eventually reroute it) and it solved the problem.. i could smell the burning and caught it before it burned all the way through so I didn't need a new wire, and now it doesn't small anymore...
If you've burned a spark plug wire, then you need to replace it, if you've burned a normal wire or plastic stuff, as long as everything still works you should be ok... however if something craps out on you in the future, suspect that wire first... ?comprende?
1992 Trans Am
May 10, 2023 07:19 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
