Power Steering Pulley On Diff Angle Then Crank Pulley
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
is this ok? i noticed today after i put on my new heads and intake that the power steering pulley is on an angle, not straight like the crank pulley. is that a bad thing?? im not sure what is causing it, the brackets are on straight? any ideas?
here is a pic:
http://img391.imageshack.us/img391/6...arts1003sy.jpg
here is a pic:
Transmission: 4L80E/4L80E
Yes, it's a bad thing. You'll be throwing the belt on a regular basis.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah but the belt never snapped, but if you look on it straight, the power steering pulley is bent it looks like. but everything looks straight maybe its the pulley itself.
oh well i guess ill drive it until something happens.
when i get paid im gonna get electric water pump so new brackets for the power steering and alternator. and ill get new pulleys.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Mine is the same way, maybe a bit worse. It worked fine for about a month then it flipped the belt, and about a week later the fan ate it
i put a new one on and its been fine ever since but soon enough itll happen again.
i put a new one on and its been fine ever since but soon enough itll happen again. Thread
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
