New PCV leak...
Old Sep 7, 2005 | 09:57 PM
Stevo's Avatar
Car: Pair of 92 Z28s
New PCV leak...
blah...getting annoyed with this car after a major oil leak...power steering leak and now this...
Put new PCV valves in...didnt leak before...passenger side does NOT leak and driver side DOES leak.
Did i put them in wrong..is there a right and wrong way to do it maybe someone can take a picture of one?
It drips some oil everynow and then and just puddles in the grooves of the valve cover...kinda annoying.
Old Sep 7, 2005 | 09:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The grommets get old and can crack.
Old Sep 7, 2005 | 10:02 PM
Stevo's Avatar
i take that is the little rubber piece under it?
and i cracked it from replacing the pcv? that would make sence of this then...
Old Sep 8, 2005 | 11:15 AM
nameinuse's Avatar
Re: New PCV leak...
Should it not be only one?
Old Sep 8, 2005 | 02:16 PM
Stevo's Avatar
Re: Re: New PCV leak...
huh? theres 2? i dont understand ur question.
Old Sep 8, 2005 | 02:45 PM
nameinuse's Avatar
Re: Re: Re: New PCV leak...
Have not seen newer PCV systems,but my 87 van had two PCV valves installed when I bought it.
One side is supposed to be just a hose with no check valve installed on my kind of engine (350),and having two PCV valves installed resulted in some leaking from the pretty bad grommets at higher revolutions when vacuum is low.
Old Sep 8, 2005 | 03:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, there should be only one PCV valve.
Old Sep 8, 2005 | 03:37 PM
Stevo's Avatar
ah...now i understand when i replaced them both...the passenger side was just a plastic tube which you where talking about...well seeing as i had 2 PCVs i went ahead and put one in there...
Then ill just change that back get a new grommet and see what happens with this minor oil leak.
thanks for the info guys.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
