baking painted parts
Old Sep 8, 2005 | 01:02 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I just painted my oil pan and want to bake the paint. What temp and for how long should I do it?
Old Sep 8, 2005 | 02:30 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I hope you aren't thinking of putting it in the oven that you plan on cooking food in. Powercoating is the only thing you do that with.
When body shops ect. refer to baking the paint, they just put it under some lights that emit heat. They don't use an oven per say. It just speeds up the paint curing process so they can move onto another car quicker.
Old Sep 8, 2005 | 09:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
depends on the paint you're using. are you just talking about baking standard plain jane paint? not necessary. Or are you talking about the hi-temp stuff that says on the can to bake it on? (like most 1500F type paints...) in which case, read the can....
but yea, avoid household ovens.... what about a bar-b-q? with flame turned real low.... (then again, it's still an open flame near a flammable paint...)
Old Sep 8, 2005 | 09:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I woulder what the fire cheif would say after their done putting out your back yard fire when you tell him you were BBQing your oil pan
Old Sep 8, 2005 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I usually put it in the oven at 200F for about an hour, then turn off the heat and let it cool to near room temperature before I take it out.
Old Sep 9, 2005 | 02:11 PM
Mike89's Avatar
Car: 89 IROC-Z
Axle/Gears: 2.77
I did this with my water pump and it worked out great. I just hung it outside from a branch or something with some bent up coat hangers, sprayed it, let it get pretty dry (to the touch), then put it in the oven on some newspaper like Apeiron said. There were no paint fumes in the house or oven and it seemed to harden the paint at least a little bit. Good Luck
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
1nastygta
Aug 8, 2015 07:38 PM
