How can I improve an old '85 IROC?
Old Oct 26, 2001 | 04:09 PM
Drylar's Avatar
Hmm. I'm reworking the exhaust a bit (had to hacksaw off the old one wsince it was badly damaged while replacing the fuel pump). Since I am near broke I am looking at replacing my muffler (with it's now gaping hole) with a cherry bomb. Hey, it's cheap. How can I quiet the cherry bomb, and reduce it's overall noise level? I have to replace everything between the cat converter to the old muffler and have a budget of $50 and has to be done tommorow at the latest.
ALSO...
Is the catalytic convert needed? I don't see why, and it'd seem to me like it would be better with a more open flow anyway. As it is, the thing rattles like a soda car with the tab broken off in it.
'85 Z28 IROC TPI LB9...
Since I am doing a bit of an overhaul any good ideas for quick, cheap, and dirty performance add ons or tweaks?
Old Oct 26, 2001 | 06:42 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
I use the Vortech Cherrybomb with a resonator where the cat normally is (no emissions). Quite a pleasing sound and really not much louder than stock.
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
Currently painting
Old Oct 26, 2001 | 06:43 PM
Enkil's Avatar
If you need to get your car smog tested, the cat is needed. You also may have some backfiring issues if you run without one. And I don't think you'll be able to do all this for 50 dollars, unless you get lucky at a junkyard.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
deracer
Apr 11, 2016 12:04 AM
Out-Cast
Aug 22, 2015 07:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Bryan F
Aug 18, 2015 02:28 PM
mustangman65_79
Aug 11, 2015 03:17 PM
