How do I bend back a part of the frame?
Old Sep 11, 2005 | 10:28 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
For the past couple of weeks my car would make to horrible scratching sound when I would make a right turn. I finally realized that its the part under the car that you hook chains up to, to tow the car. Apparently last time my car was towed that the passanger side piece bent. Any idea on how to bend back a piece of steel?
Old Sep 11, 2005 | 10:33 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
got any pics of it?
Old Sep 11, 2005 | 05:59 PM
Vader's Avatar
What part?
Attached Thumbnails How do I bend back a part of the frame?-frontsuspensiondetail.jpg
Old Sep 11, 2005 | 06:54 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
This is the part thats bent
Attached Thumbnails How do I bend back a part of the frame?-metal-piece-001.jpg
Old Sep 11, 2005 | 06:56 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
This is the one on the driver side
Attached Thumbnails How do I bend back a part of the frame?-metal-piece-002.jpg
Old Sep 11, 2005 | 06:59 PM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
I'd heat it up with a torch and wack it with a hammer. Someone else might have a better idea though
Old Sep 11, 2005 | 07:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, no heat just wack it. did you find the cause of your noise? or is this somehow rubbing
Old Sep 11, 2005 | 08:12 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
I think that part is somehow rubbing because I can't find any parts under the car with fresh scratch marks.
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
1nastygta
Aug 8, 2015 07:38 PM
