need tips on tuning a 305
Old Sep 12, 2005 | 05:30 PM
MKnight's Avatar
Hey guys, is it worth it putting platinum sparks on this engine and if so, what is the optimal spacing for the plugs to get the most out of them? Any advice would be most appreciated.
Old Sep 12, 2005 | 07:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll get more benefit out of a good coil and module. Those high-dollar plugs exist to crutch weak ignitions. Standard copper plugs will do just as well with a good ignition as any other type of plug.
If the ignition is otherwise up to snuff, .005-.010" increase in gap over the stock recommendation is usually a safe bet. Experimentation is required to determine the optimum gap your car wants. If you aren't willing to spend the time required to do that, set them to factory specs.
Old Sep 13, 2005 | 12:44 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
the best tuneing option for a 305...pitch it for a 350! j/k.... my recomendation is some basic bosch plats... like $2.15 a plug here.. if you want a gap thats a little biger i'd agree with five7kid no more then .010 over with stock plugs, wires etc.
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fast355
Dec 2, 2016 06:33 PM
BurlyChev
Aug 22, 2015 11:42 AM
theurge
Aug 21, 2015 12:46 PM
