Coolant in Cylinder
Old Sep 13, 2005 | 07:21 PM
tallguy's Avatar
Car: 3rd Gen TA
Engine: 5.7
Coolant in Cylinder
Ok everyone - here's my problem:
I just dropped in a carbed 350 and ripped out the POS 305 TPI.
I just put all new hardware on the top end of my engine. New heads, new push rods, roller rockers, intake and carb and thought it was pretty much buttoned up.
Now when I go to start it, my #1 and #2 cylinders fill with water. Now I'm the first to admint that I'm no expert when it comes to engine rebuilding, but I'm far from a beginner. This one stumps me and its quite disappointing!
Any ideas?
Old Sep 13, 2005 | 07:30 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Either a cracked head,headgasket not sealing,likely due to a warped head or unsquare block deck.
Take your radiator cap off,cold,disable your ignition,and have someone crank it over.If your coolant bubbles,you know it's one of the Two
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
