Too Lean
Old Sep 14, 2005 | 10:49 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Too Lean
1983 5.0 liter with computer-controlled carburator.
For some time, the car has idled rough.
Checked timing, as I thought that the chain might have slipped a tooth. Timing is where I left it after doing the work mentioned below.
Checked vacuum. Very high at 25" Hg.
Changed O2 sensor.
Pulled plugs. VERY LEAN. All plugs have snow-white porcelain, with just a touch of tan residue.
If the intake gaskets were leaking, the plugs would be a variety of colors. I replaced them and the carb gasket last fall, as I was loosing anti-freeze.
Can I have a vacuum leak, in spite of the high idle reading?
Is the repair simple and obvious?
What do you think?
Thank you,
Seth
Old Sep 15, 2005 | 12:22 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the timing chain is known to be bad, change it. A streched or jumped chain will cause all sorts of problems and headaches for you.
Old Sep 15, 2005 | 08:56 AM
The chain does not appear to be an issue. I simply needed to check whether the timing was where I had left it,; because when you replace the intake manifold gasket(s), the distributor comes out with the manifold.
Thanks,
Seth
F-body-fan
Jan 12, 2023 01:49 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
