Oil press. sender
Old Sep 15, 2005 | 04:51 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Oil press. sender
Hey guys,
I noticed when I finished the engine swap ..
my oil pressure guage pings 60 lbs all day long.
I look, everything looks good .. so I disconnect
the sender to check.
So, knowing how senders work, you should be able
to ground the sender wire to the frame of the car for
it to jump back to 0 right??
but, it doesnt even flicker .. bad sender unit??
This is the way to check for a bad unit right?
Thanks in advance
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
