gas tank differences
Old Sep 1, 2005 | 10:34 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
is there any difference in a carburetor gas tank and a tpi with intank pump, besides the sending unit?
Old Sep 2, 2005 | 11:14 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I asked the same question on another board in Third gen. I'm going to need a new tank and SPI makes two one for FI and one for carbed. I called SPI and there is a "pan" inside the FI's so to not fry up the pump if gas gauge is on "E". I'm not sure if that helps you at all....
Old Sep 2, 2005 | 11:23 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well i noticed looking in the classic industries catalog they list the same part number for the carbed and fi tanks.
Old Sep 2, 2005 | 02:54 PM
Car: 1982 Z-28
Engine: 383
are you looking at GM2721A and GM2721B
Old Sep 3, 2005 | 10:02 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well i actually have an older catalog they list...
85....all models G6962
86....5.0F, 5.7-8 (Tagged FES,FEV) G6962
91....3.1T, 5.0F, 5.7-8 G6962
Old Sep 13, 2005 | 11:52 AM
Car: 1982 Z-28
Engine: 383
Well to answer the original question of if there are any differences the answer I got from SPI is yes. FI tanks have a plastic pan in the tank so the fuel pump is always submerged in gas.
This goes for the replacement tanks, not the OE tanks..but I'm sure they are all on the same idea...
Old Sep 15, 2005 | 05:55 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
If your worried about using a FI tank with a carbed motor, use an electric pump with a regulator. If you are worried about using a carb tank with a FI setup, holley has a 255gph (i think it's that big) mechanical pump that you can use.
I have a FI tank from a V6 with a 192GPH ford fuel pump feeding a mallory regulator for my carb.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
