Fuel Pump or Pressure Switch?
Old Sep 15, 2005 | 05:18 PM
weigesco's Avatar
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
I am running the stock intank TBI fuel pump to a Mallory 3 Port Return regulator to a Holley 750 Carb. Here is the problem, when I first turn the key on the fuel pump primes fine. After starting the car though I don't get any fuel pressure. Carb runs out of fuel and car dies. Turn key fuel pump primes fine. While trying do diagnose this, I hooked up another fuel pressure gauge and still showed no fuel pressure. Then all of a sudden got fuel pressure on gauge and ran fine. Turned off car, let it sit for a while, now I do not have fuel pressure again. Any ideas on this? Could it be the oil pressure sensor?
Old Sep 15, 2005 | 06:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds likely.
Old Sep 16, 2005 | 04:44 PM
weigesco's Avatar
I fixed the problem. It appeared that the Fuel Pressure Relay wasn't working. I tested it by running a hot lead from the battery and spliced it into the Tan/White wire on the Fuel Pressure Relay. As soon as I did this the fuel pump kicked on and the car started and ran fine. I then found a switched ignition source to tap into the Tan and White wire instead of going direct to the battery.
Old Sep 16, 2005 | 07:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The fuel pump relay doesn't work without a functioning ECM in the car.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
