oil pump pressure spring
Old Dec 3, 2003 | 11:20 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
what is this and what does it do to the oil pump--- a Mr Gasket 26 pressure regulator spring. i have a melling oil pump and was curious as to what this spring would do to the pressure out put???
Old Dec 4, 2003 | 12:32 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Inside the oil pump, there is a piston. The piston is pressed aginst a hole by the spring. Oil from the oil pump outlet is on the other side of the hole. When oil press exceeds spring press, the piston moves away from the hole and oil is bypassed from the pump outlet back into the pump inlet.
That Mr Gasket spring will limit oil press to 60 PSI which is a little higher than stock.
Old Dec 4, 2003 | 04:58 AM
ede's Avatar
ede
it's a good mod to make to the m55 pump, and simple to do
Old Dec 4, 2003 | 05:10 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
THANKS FOR THE INFO I WILL PROBABLY DO THIS BEFORE I GO BACK TOGETHER
Old Sep 16, 2005 | 12:35 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Where can you get this spring? Will an Autozone type place carry this?
Old Sep 16, 2005 | 08:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Anywhere that carries Mr. Gasket parts.
jklein337
Sep 19, 2018 06:23 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
