Timing and the ECM
Old Oct 29, 2001 | 11:12 PM
Adam62083's Avatar
Timing and the ECM
Here goes
My timing was way off when I went to the track and I ran some down right crappy times. My L98 was running like a L03.
I reset it from way off the richter scale (im guessing it was like 10* BTDC)
Anyway I pulled it down some and kept having the same problem of no real bottom end power and sometimes the motor would die when shifting from park to reverse or neutral to drive, etc.
Now it is set at 2* BTDC and seems alright. It was set last night. I have driven it around some last night and tonight, and tonight it actually feels a "little" better than the night before.
Is this the ECM relearning what the timing is or am I imagining things or what?
Thanks,
Adam
1992 Formula 350
-SLP 1 3/4 Headers
-Ported Plenum, Polished w/ polished runners
-Airfoil and other small bolt on mods
Old Oct 29, 2001 | 11:15 PM
breathment's Avatar
have u checked the vaccume? is the car running good other then that? tune up etc?
and just to be certain, did u uplug the connector thingy, i forget what its called.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited October 29, 2001).]
Old Oct 29, 2001 | 11:23 PM
Adam62083's Avatar
Yeah the connector thing was unplugged when i set it.
Also the car has new wires and plugs, cap rotor and coil all about a month or two old.
Is there a way I can check the vacuum? Thats where I think the problem lies, is I am getting low engine vacuum. What causes that?
Old Oct 30, 2001 | 02:26 PM
Adam62083's Avatar
Anyone?
Old Oct 30, 2001 | 04:22 PM
breathment's Avatar
goto auto zone and pick up a vacumme guage. only 19.99. then hook it up to a vaccume line, i usualy use the Fuel pressure vaccum hose. as far as the causes, there can be many, broken or unconnected vaccum hoses. intake manifold leak.
- David
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
ezobens
Aug 19, 2015 10:29 PM
