350 swap
Old Oct 29, 2001 | 08:40 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
350 swap
Thinking about putting a 4bolt 350 out of an 80 1 ton in my 87 firebird. Do our cars use a vehicle specific oil pan? Also what else do I need to change? Knock sensor? My car is an LG4 and I'm going to keep all the stock carb etc.
Also what compression ratio will work with the stock distributor and computer?
Old Oct 29, 2001 | 09:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You're going to have to get a different flywheel.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 29, 2001 | 10:32 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
thanks. I knew that one though. one peice to two piece seal. anything else?
Old Oct 30, 2001 | 07:13 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Flywheel and elongation of intake manifold bolt holes. Do yourself a favor and buy a gasket kit to throw on it before you put it in the bird. They make a one piece oil-pan gasket that would be a good idea. A cam might not be a bad idea, so a timing chain ... why not an oil pump
Old Oct 30, 2001 | 08:51 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
If it goes in the bird it will be brand new. I've been pricing parts for rebuilding it or the birds 305 and am coming to the conclusion its getting the 350. Although I may put the 350 in my truck and take the 327 out of that to put in the bird. Havent decided. I'm trying to figure out just what all I may have to buy for the 350 to make it fit. I need both rigs running and I can have the 350 rebuilt and ready so I can swap in 1 weekend.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
