thinking about 305 buildup
Old Sep 18, 2005 | 02:41 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
ok, this is my plan for right now. i got the gutless LG4. i was thinking about going with an l98 cam and porting the stock heads. with a nice intake and exhaust how much power will this add? also, would roller rockers be a worthwhile mod or not needed at this stage?
Old Sep 18, 2005 | 05:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
look up sitting bull, he did about the same and got roughly 300HP.
why not a 350 block? or is your short block ok now?
headers are your best bet?
Old Sep 18, 2005 | 05:52 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Good luck trying to find an L98 cam that works in a flat tappet block.
Old Sep 18, 2005 | 05:55 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
actually i will be using an lb9 short block, l98 cam, and the ported lg4 heads..does that sound like a good combo?
Old Sep 19, 2005 | 03:07 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
He could get an '85 Trans Am TPI cam. That's the flat tappet L98 cam if he were to stick with his block.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
