Plug wire routing
Car: 1991 Trans Am
Transmission: 4L60
Plug wire routing
Ok, I'm going to try to ask this again. Is there any reason I can't run my plug wires over my valve covers when I install my TES headers next week? I bought some MSD universal 8.5 mm wires to route them anywhere I want...or need.
91 TA 5.7 TPI Automatic
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube), Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs, JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" cat-back, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 synthetic fluids.
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Yeah... the drivers side should be ok, but your gonna have problems with the passenger side... read on as Ill try to explain this as best as possible.
Heres what I did and it seemed to work for me on both of my cars and a few of my friends aswell.
There isnt enough clearance between the heads/hedders to safely run the wires on the 2 rear passenger side cylinders... if ya do, youll burn em up like i did.
1. Start off with the 2 longest ANGLED boot wires... take em out and set em aside.
2. Put on the rest of the wires on all but the back 2 cylinders on the passenger side... as these are reserved for the 2 longest angled boot wires you allready set aside.
3. Now, take the 2 wires you set aside before, and put them on the back 2 cylinders. I like to run them towards the FRONT of the engine, meeting the front 2
wires. Use a 4 wire loom where the 2 wires coming from the back meet the front 2 wires.
Running the 2 back wires UNER the headders towards the front 2 can greatly reduce the chance of smokin' a wire.
Heres a hint to install the hedders if ya dont already know:
1: Unbolt the AC compressor, leave all the hoses CONNECTED, and take it outa the bracket and move it outa the way as much and as safely as you can. The hedders will drop right in.
Drivers side:
Remove the alternator, and remove the hard fuel lines the run behind the alternator and into the fuel rail. They'll drop right in there too!
Thats it... I kinda wish I knew this before I put my first set of headders in... but hell i learned the hard way!
Good luck man!
-Rob
92' White Trans Am Convertible, 305 TPI, 5 spd. 2:73's, Edelbrock TES, Accell 8.8's, Hypertech Stage II, TPIS Air Foil, Ported Plenum, K&N TB Cone Filter, AFPR, & A Little Bit Of Attitude!
-Best ET: 14.944 @ 93.11
88 Gunmetal GTA Hardtop... Project In The Works!
"GUYS, WE NEED TO FIND A MUSTANG TO RACE... THERES ONE! HOLY SH*T SHES HOT! SHES NOT GONNA GO... NAH... HOLY SH*T SHES GOIN!"
Drivers side:
Good luck man!
-Rob
Car: 99 Formula
Axle/Gears: 342
I had the same problem with the #6 and #8 wires as well. What I did was route them over the heater core hoses and thru the looms, they stay about an inch from the headers. I would definately invest in some looms, in the past I tried it without looms and burnt 3 wires. Not too mention riding around with the motor running like crap not knowing what the problem was.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
eightsixseven
Dec 16, 2024 01:50 PM
