Help! How do I remove the power steering pump?
Old Nov 1, 2001 | 01:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm trying to remove the whole bracket fromthe head for a head swap but I got to get the pump off first and I cant find any mounting bolts. help Thnaks
Old Nov 1, 2001 | 01:10 PM
JeffT's Avatar
Car: 1991 Z28
Mounting bolts are behind the pulley. You will have to pull the pulley off to get to the bolts.
Old Nov 1, 2001 | 01:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
bastard ok thats what i thought. Use a 3 jaw puller?
Old Nov 1, 2001 | 01:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
how do i press it back on when teh pump is back in teh car?
Old Nov 1, 2001 | 02:06 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Don't use a 3 prong puller. You'll tear the pulley up. What you need to get is a PS pulley remover/installer. Sorry, I can't remember the exact name. This will both remove and install the pulley for you.
Good Luck!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Nov 1, 2001 | 02:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
oh ok thanks. I'll borrow one from autozone then.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
