Help
Old Sep 23, 2005 | 05:11 PM
n2omike's Avatar
Car: 86 WS6 Trans AM/ 95 Trans Am
Engine: 305/Lt1
Transmission: 700r4 / 4L60
Axle/Gears: ? / 3:23
Help
I need help. I just changed from Cumputer controled carb and dist to a regular HEI and Edelbrock carb. Now I dont have any spark to the spark plugs, but I do have 12 volts to the dist. Any ideas?
Thanks in advance
Old Sep 23, 2005 | 07:13 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
did you plug the coil in the top of the disty? there should be 3 plugs that go into the cap and actually plug into the coil... if you have the two outside ones reversed it will not work. Also if none of them are plugged in then it will not work (except for the tac.... (the one closest the firewall on the outside..)
looking top down it should be like this
| | | <------Tach
| | | <------12v i believe
from base of disty (ICM and pickup i believe)
I do believe that is how it is.. at least that is how it is on my non CC HEI disty.
Also If you bought the things used it is always a good idea to rebuild the thing. just to make sure everything is top notch.. Like Cap/coil/ICM/Pick-up/Rotor/Mech advance springs/vac advance canister.. That way the disty in in top notch working order. (I am doing all that as I type.. Last thing needed is the springs for the mech advance, and then an adjustable vac advance can.... Went and bought everything else. but they did not have the springs i wanted nor and vac advance cans that were adjustable.
Old Sep 23, 2005 | 08:06 PM
n2omike's Avatar
Engine: 305/Lt1
Yea I did plug the coil in also tried a diffrent coil. I did put in new cap,rotor,pickup and mod .
I belive my 12v wire is on the back near the firewall. It is marked on the cap wich one is wich also.
Thanks for your help.
Old Sep 23, 2005 | 08:07 PM
really on mine it is marked as the tach... odd
Old Sep 24, 2005 | 08:02 AM
n2omike's Avatar
Engine: 305/Lt1
Maybee I should switch them.
Old Sep 24, 2005 | 04:58 PM
n2omike's Avatar
Engine: 305/Lt1
Never mind I found the problem. The capacitor in the dist was bad. What a headache that was to figure out.
Well now I have a rebuilt HEI I guess since I replaced everything in it
Now on to the next phase of the project.
