OIL FILTERS- comparison by height
Old Sep 23, 2005 | 08:07 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Anyone who works around oil filters regularly knows that an M40A and an M454 have the same threads and gasket diameter... They're just different heights. Whether or not you knew this, lets just think for a minute...
A small block chevy calls for an M454, so that's what I've got on there right now. However, the M40A is about an inch and a half taller, thus more filtering area. For a high performance application, in addition to oil longevity (Mobil 1 synthetic, 5w30) should I be using this taller filter? Or should I just stick with the shorter M454 which both the computer and filter book call for?
I mean, neither would hurt anything, and they're both the same price- so which would be optimal? Common sense tells me the taller M40A... Thanks guys
Old Sep 23, 2005 | 08:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use the taller one if you want.
BTW only people who work with your particular brand of filter might know that.
Old Sep 23, 2005 | 08:48 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
The numbering system is used by FRAM, Mighty, and some other large filter company... I forget who.
Old Sep 23, 2005 | 08:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Fram calls it a PH5, not an M40A. To AC Delco it's a PF1218.
Old Sep 23, 2005 | 09:03 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Regardless of the numbers, until you cut them both open and check, you may not have more filtration area. What if the larger one has less pleats in it?
Old Sep 23, 2005 | 10:07 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
good one
Old Sep 23, 2005 | 10:08 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
fram uses a lot of similar numbers
3387, 4651, 4670
Old Sep 23, 2005 | 10:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I also despise Fram filtration systems.
Like Devilman said, taller, shorter, doesn't matter. Between companies, yes, the taller would have more filtration surface. But comparitivly to other brands it may not.
Old Sep 24, 2005 | 01:26 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I don't touch FRAM
Old Sep 24, 2005 | 03:43 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
If you want a *real* filter get a Donaldson P166564. It's a high performance synthetic media filter direct replacement for the good old AC PF35L.
They ain't cheap, but neither are synthetic oil and hot-rod engines.
Old Sep 24, 2005 | 04:31 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I get my Mobil 1 for about $3.75 a qt, so it's no big deal
Old Sep 24, 2005 | 04:52 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's more to the benefits of a larger filter than surface area of the filter media.
Keep in mind that the two filters are ~1/2 quart different in capacity.
Oil not only lubes the engine, it also helps cool it. That 1/2 quart may not only cool the engine, but keep the overall temp of the oil cooler also.
The only concern two concerns I'd have are
1.) The filter getting scraped by a speed bump, or who knows whatever else especially if the car had been lowered.
2.) The filter being closer to the exhaust, especially if you're running headers. The heat from the exhaust may be enough, if not too much, to overcome the benefit of having more oil present.
I don't believe that's a problem with the stock 'Y'pipe, but it's been a while since I've changed the oil on my car. It's been sitting by the garage for over a year now.
Old Sep 24, 2005 | 05:00 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
yeah the filter has plenty of clearance, and the headers/y-pipe are out of the way. I might as well just toss on the bigger filter- you're right, if not for better filtration and collection, better cooling. Never thought of that.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
dbrochard
Sep 19, 2015 08:13 PM
CatmanFS
Sep 19, 2015 09:00 AM
85Special
Sep 3, 2015 04:21 PM
