Running rich....please guide me to a fix
Old Sep 24, 2005 | 01:24 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
Hello all...own a 89 (not 88..sorry) 350 TPI...starts up fine..idles fine..no codes present or stored currently...as she warms up...dark colored smoke..even has a slight bluish tint to it starts to flow out exhaust..my eyes start to burn..and the smell of "RICH" is all I can smell.looking for help in a diag sequence to solve this problem,The O2 is 6 months old..I R&R'd it for regular maintenance..she has been running fine up to now untill this rich issue.I want to know from you people ...before I dig myself a diag holeI can't get out of.
thanks for your time guys.
Brent Rndsout@comcast.net
If you need more info.....fire away...I would really like to solve this,and learn @ the same time.
Old Sep 24, 2005 | 08:42 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Bad valve seals
Old Sep 24, 2005 | 09:28 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
valve seals will cause a puff of smoke on start up.
Old Sep 26, 2005 | 05:03 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
Hey guys..thanks for getting back to me.
Well I found the problem,but its not the valve seals,they are new.A bad MAF "power" relay,kinda wierd seeing how it didn't set a code.Must have caught it early enough I guess.So I found out that a bad MAF power relay would cause a massive rich condition..so I checked to see if the power relay was energizing...NADA....the burn-off relay was working,but I replaced both instead.Car runs great now..no stinkin ..eye burning..rich running issue. I do have one more question if you people have the time.
I have installed a Lunati cam.. 0.469int 0.489ex
206int 215ex @ 0.50 now the cam card tells me that if cam is installed @ TDC...the cam will be 4' advanced.Now my vehicle runs awesome,I have set the initial timeing @ 8' on the balancer which I'm wondering if thats too much seeing how the cam is already 4' installed straight up(TDC)which would make a grand total of 12'..is this correct???? I mean..am I makeing sense here??.What would you guys set the timeing in this situation.
Thanks again guys
Brent
Old Sep 26, 2005 | 05:10 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
I run my base timeing at 14* Im not an expert and if Im wrong someone will point it out, but as long as you dont have knock at 12* you will be ok. My friend has a 71 camaro and runs his base at 16*
Old Sep 29, 2005 | 08:39 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
I'm going to keep @ 8' for now..no harm-no foul.
Thanks again
Brent
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
