Fuel gauge moves with every bump
Old Nov 4, 2001 | 02:57 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
My fuel gauge moves with every bump in the road. Not the normal GM type floating movement when you brake hard. The sending unit is new and the gauge reads correctly when sitting still for a minute. Could it still be the gauge?
Old Nov 5, 2001 | 01:34 PM
Biochem's Avatar
Car: 2002 SOM z28
Most likely the sender unit in the tank... mine does the same thing with a different gauge.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
