Hesitation about 4,300 rpm.. please help
Old Nov 4, 2001 | 04:44 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I thought it was my coil, but have replaced that with the Accel Super Coil. I know think it could be mr Holley 750 double pumper.
It is only when you have your foot fully down and the revs get to 4000 or so and you can actually hear it sort of clacking (best way of describing it) I did 700 miles last week and thought it may clear but it hasn't. Also when you are going say 20 mph and put your foot down a little (say half throttle) there is an induction back fire. This is followed by a highway speed problem of the throttle sticking at speeds of 70-80 mph. If you tap the throttle again it is ok again. Then maybe 10 mins later its fine again.
Could it be a float sticking? Could it be my timing?
Please help, the car runs well aprt from that and it is beginning to pee me off now. Thanks
'86 IROC ZZ4
Holley 750 dp, Shorty Headers, BW POSI 3.27 rear, Southside sfc's, Probuilt 700r4, Hurst Dual Gate Shifter.
Best Run 13.8 @ 100mph- far more to come!
London-England (Brothers In Arms)
British Firebird/Camaro Site
Old Nov 4, 2001 | 08:08 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
To me it sounds as though you're getting too much fuel at low RPM and not enough at higher RPM. Although there is a small possiblility of a timing issue. I would check my timing and then look at the carburetor first. Accelerator pump(s), jetting etc. If you still can't get it worked out put up another post.
Old Nov 5, 2001 | 02:02 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks man, I'll check it out and let ya know. It isn't too bad on the street as I hardly ever need to use that kind of power but you really notice it at the strip.
Cheers
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
