lean or rich?????
Old Nov 5, 2001 | 02:47 PM
88greyiroc's Avatar
lean or rich?????
how can you tell if a car is burning too rich or too lean i guess k&n has out a device to measure it but it would like to knowmif there was any way to tell without that.and what are the side effects of burning too lean and too rich.what i mean is the difference between rich and lean.
Old Nov 5, 2001 | 07:31 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Get an air to fuel ratio gauge. That will tell you if it is running rich or lean. Running lean isn't a good thing. I would prefer to run too rich rather than too lean. A piston with a hole melted init isn't so good for performance.
Rob
Old Nov 5, 2001 | 10:55 PM
Vader's Avatar
Or you can use the Field Service Mode of the ECM as a general indicator of the fuel mixture. If the ECM is trying to enrich the mixture, it's running lean, and vice-versa.
Do an archive search on "Field Service Mode" and you should find detailed instructions.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
