Does anyone make shorty spark plugs for aluminum heads?
Old Nov 3, 2001 | 04:39 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I can't seem to find any header (shorty) plugs for aluminum heads. Does anyone have a part#? I am having "issues" with my Edelbrock RPM's and my SLP 1 3/4 headers
Old Nov 3, 2001 | 04:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Bosch Platinums are shorter than average.
Old Nov 3, 2001 | 05:05 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I don't think they are short enough. I am using RapidFires. How much shorter are Bosch's?
Old Nov 3, 2001 | 05:42 PM
irocbsa's Avatar
Accel makes shorty plugs for engines with headers. Give them a call. Their number is on their web site.
bsa
Old Nov 3, 2001 | 06:32 PM
rezinn's Avatar
I have aluminum heads and edelbrock headers, bosch plats are good for me.
Old Nov 3, 2001 | 08:23 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Accel does not make the shorty plugs for aluminum heads. I have 1 3/4" SLP headers so I am having some problems. The plugs in #6,7,and 8 touch the headers.
[This message has been edited by Acceld Z (edited November 03, 2001).]
Old Nov 3, 2001 | 09:10 PM
Guest
Guest
Posts: n/a
I was looking about 6 months ago, couldnt find squat. The shortest are apparently the NGK's and Bosch plugs, although I have not sat down and measured to see if they are shorter than the AC plugs or not.
Old Nov 4, 2001 | 03:02 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Are these angle, or straight plug heads? Just wondering for future reference....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 4, 2001 | 08:34 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
They are angle plug heads. I think i'm screwed. I'm going to need a shorty plug and dimple the header but even shorty plugs only give you about .25" extra to work with.
Old Nov 5, 2001 | 12:31 AM
Engine: 305-4v
Keep heatin' 'n hammerin' and I think you'll be alright.
Would have been a good time to choose 1 5/8 headers, I guess.
Old Nov 5, 2001 | 02:45 AM
Matt87GTA's Avatar
Well I don't remember seeing too many other people having that many problems with the SLP headers so maybe give SLP a call and see what they say..... They might have an idea or two for ya..... Worth a try anyway....
1987 GTA L98 MD8
My GTA
Old Nov 5, 2001 | 09:03 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Are you talking about R&R the plugs or once the plugs are installed the boots won't clear the headers?
My buddy has had Aluminum L98 heads and then just installed AFR 195s - both angle head and both with his SLP 1 3/4" headers.
To R&R the plugs, he had to make a spark plug tool by grinding both ends of a spark plug socket to clear the headers to tighten and loosen, with a box end wrench at the end.
I had to make a similar socket for R&R'ing my spark plugs on my stock L98 heads with Edelbrock TES headers. I use a ratcheting box-end that goes on the end of the cut-down spark plug socket.
Once the plugs are installed, there is no problem with the boots burning on my buddy's or my car. We both use MSD Superconductor 90* plug wires.
Old Nov 5, 2001 | 07:50 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Unfortunately nobody makes a shorty style gasketed type plug. I went through this mess earlier this year with SLP headers and my angle plug AFR's. I ended up getting a set of Hooker S/C's full length headers to make those heads work. Oh well, it's only money right
Old Nov 5, 2001 | 07:55 PM
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by Acceld Z:
They are angle plug heads. I think i'm screwed. I'm going to need a shorty plug and dimple the header but even shorty plugs only give you about .25" extra to work with.</font>
On the first page of the January 2002 Chevy High Performance they have an ad from Jacobs Electronics which displays a set of porcelain ended spark plug wires, with rubber only at the the portion that touches the spark plug. The majority of the boot seems to be porcelain! Sounds like it may be an answer to your problem.
Old Nov 6, 2001 | 06:11 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I might be able to get this to work using a combination of short plugs, dimpling the headers and ceramic boot jackets. Overall I need to come up with about 1" of clearance. Is it possible to double up the header gaskets to move the header off the block more? Just in case, does anyone want to trade a set of 1 3/4" SLP headers for a set of 1 5/8"s? They're new
89GTA-The Driver
92Z28-The Lawn Ornament
"Sunday Money"
Old Nov 6, 2001 | 06:45 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Those Jacobs wires are $200 for a set but they might do the trick
89GTA-The Driver
"Sunday Money"
Old Sep 23, 2002 | 04:14 PM
gtabadboy's Avatar
I need shorty plugs too. My Accel short plugs cleared but they dont have a .75 reach, .046 is the biggest. Thats why my car is running horrible. Other plugs touch my headers. Will the DEI boot covers stand up to header heat if they are touching the header?
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
