Piston to Valve clearance- how do you do it with a Dial gauge?
Old Nov 1, 2001 | 04:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How would you measure piston-to-valve clearance with a dial gauge and stand? Using the modeling clay makes sense.. this doesn't. I'm probably missing something really obvious! Plus, how does the degree wheel fit into all of this?
Also, here's an easy one: It makes no difference if a degree wheel is used on a V8 or V6, right?
Thanks!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 1, 2001 | 05:10 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
It makes it easier if you have some soft springs. That way you can turn the motor over at very small increments.
Put the light springs on the #1 cylinder. Put the dial indicator on the valve spring retainer. Make sure the cam is on the basecircle.
Depress the dial indicator until you have about .4" of the dial indicators range used. Now Zero the dial indicator.
Rotate the motor through the overlap cycle (at about 10 degree intervals) and press the retainer down at each 10 degree point. See how far the dampener goes before it contacts the piston at the valve reliefs. That is your piston to valve clearance in thousands of an inch.
V6 or v8 does not matter.
I think thats it. If i have misquoted something this group will surely point it out.
Old Nov 2, 2001 | 01:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow! Thanks! So it's not the actual camshaft that moves the valve for checking, it's me pressing on the valve? Now, I guess if I find out I've got zero clearance, that's when I stop turning the crankshaft, right?
Then, would I spin the crank "backwards" to find out at what range of degrees the interference is?
Er, wait... how do I know how "far" is okay? Seems like I could push the retainer (as in valve stem?) down as far as I want to, and always hit a piston... or, does it not matter, just so I know the clearance?
Thanks!
Old Nov 2, 2001 | 01:45 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
Yes, you are going to manually determine how much is left after the cam puts it at the closest proximity.
</font>
Yep . Even though it's not likely. In most cases, if that has happened, the dots were not correctly aligned up on the timing marks.
</font>
You need about .1 inch between the exhaust valve and the piston and at least .090" for the intake.
If its over .1 inch (one full rotation of the dial indicator), you are good to go.
Old Nov 5, 2001 | 11:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks! I kind of want to tear my engine apart just so I can try this! Is more clearance needed for the exhaust valve because it expands more with heat?
Old Nov 5, 2001 | 02:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Yep, thats the biggest part of it.
I would not do it just for grins though..
Old Nov 6, 2001 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs) Thanks again!
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
