EGR Solenoid Routing
Old Sep 29, 2005 | 07:55 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
On the L-98 TPI egr solenoid, which port is the vacuum supply and which port goes to the egr?
Old Sep 29, 2005 | 08:21 PM
Vader's Avatar
The Gray line is routed to the bottom port. The black line is routed to the top port:
The gray line should be connected to the "T" fitting under the throttle body. The black line connects to the EGR valve pilot diaphragm.
Old Sep 29, 2005 | 08:37 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Thanks for the info Vader
F-body-fan
Jan 12, 2023 01:49 PM
88CamZ
Oct 8, 2015 10:29 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
