Heat soak? Maybe not
Old Sep 30, 2005 | 09:53 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I have had trouble with starting my car when hot, well i thought when hot.
Here is a run down on my car.
1991 firebird 355 tpi, headers
I thought at first it was a heat soak issue with the starter, so i put a mini starter on it, thinking the problem was solved. Wrong, after extended driving at all it will only click when i turn the key, just one click, all the while i have power to everything else.
Well this morning it decided to do that after it had sat in the 40 degree temps we had here last night, so i think i can rule out heat.
My vats is bypassed, meaning we jumped the starter relay, and it is gone in my chip, what else can i start to look for?
My search yielded a lot of heak soak problems, which i believe now i do not have.
thanks
Old Sep 30, 2005 | 02:14 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Have you checked the condition of the cable going from the battery to the starter? What are you reading power wise at the starter?
Old Oct 1, 2005 | 10:57 PM
9D1BURD's Avatar
Car: 1997 Z28
cables are new, i have yet to check voltage, doing that tomorrow i hope.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
