How to tell if your fan switch sensor is bad??
Old Nov 6, 2001 | 06:57 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
My fan isn't turning on and both uper and lower radiator hoses are just as hot.
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
97 Firebird 16X8" Rims
Old Nov 6, 2001 | 08:37 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Just unplug your power wire on the fan. Then take some spare wire and run it straight from the battery terminals to the plug on the fan. If the fan doesn't start, then your fan is bad. If it starts then it is probably the temp sensor. You may also want to check all the wiring just to make sure nothing is lose, especially a ground wire.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
Old Nov 6, 2001 | 09:31 PM
michael's Avatar
Car: 1991 Formula
Does it matter what terminal you touch with neg/pos????
breathment's Avatar
i wouldn't think so, if u reverse the polarity then it would probably just make the fan go the other direction
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 7, 2001 | 04:02 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
No it doesn't matter, the third response is correct if you hook it up backward it will just spin the opposite direction.
Old Nov 7, 2001 | 08:13 AM
mvftw's Avatar
I just went through this senario Sunday. This is how it works...the fan doesn't come on till about 230* on V6's, so it may be Ok . This is how to check out the whole system. You jump out the fan first by putting 12v on the black/red wire on your fan. If that works, next there is a small round switch (w/1 wire Grn/wht)on the pass. side head towards the back (hard to get to), squeeze the connector and ground the switch, that will turn on the fan relay and the fan on. If that works the only thing left is a bad (weak) fan relay switch (the one you disconnected) or there is nothing wrong, your not waiting long enough.
Hope this helps...
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
TA8487
Aug 16, 2015 12:21 PM
