another 3.4 question
Old Oct 2, 2005 | 02:17 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Before anybody asks, Yes i have searched for about 30 mins (give or take a few mins)and there really wasnt anything usefull that i found, My question is, Can i make the 93-94(95?) 3.4l v6 blocks work with the carbs? if i understand the 3.4l's correctly they were all DISless blocks? is there a plate or something covering up where a Distrubuter could/would go?
Old Oct 2, 2005 | 01:02 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
you can make them work with a carb. I swapped one form a 96 camaro in place of the blown 2.8 in my jeep using the jeeps original carb, manifold and distributor. The distributor hole is blocked by plug that is basically the bottom halve of a distibutor. It's kind of hard to get out because you don't have much to grab on to but I used a big pair of channel locks and it came right out. There is also a cam sensor in the front of the block but I just left it in. Also the 3.4 has no provision for a mechanical fuel pump but I used a universal external pump for a carb.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
