what type dist cap for 86 TPI?
Old Oct 2, 2005 | 10:21 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
I am converting my 86 Iroc-Z from carb to TPI. The TPI set-up I have included the distrubutor but not the cap and coil. Do the 86 TPI 305's use a tall cap with coil on top or the shorter cap and coil mounted on firewall? If you have the correct part number I would be greatful for that to. Thanks
Tony
Old Oct 2, 2005 | 10:43 PM
Vader's Avatar
No, and no.
The '86 HEI system in most cars used the "tall" cap with an integral ignition coil. '87 and later engines had the smaller diameter cap with a divorced coil. However, the '86 TPI just had to be different. since the TPI allowed little clearance, the TPI engines used a special cap that was lower, yet still had the coil mounted to the top.
Conrad/Wells DR2009G is a good unit for the price. It has a GRP body, deep arc chutes, and solid brass contacts. Don't get the regular 2009, but use the 2009G. The 2009 is just a plain old replacement cap, aluminum contacts, thermoplastic molded, and is a basic 10,000 mile cap. AC/Delco has the same type replacement, as does Standard Motor Products. Again, get the better unit.
Old Oct 2, 2005 | 10:48 PM
Car: 1986 Iroc-Z
Vader - you are an amazing wealth of information! You helped me a little while back when trying to figure out some vacuum lines. I am starting my carb to tpi conversion this Friday and this was my final purchase - I hope ;-) I really appreciate the help on this one. All TPI's I had seen were low caps and divorced coils but good old 86 had to be different. I will take your advice and buy that particular one right now. thanks again
Tony
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
