where does the iol pressure sensor go?
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I've looked around but I cant see anything. I found 2 ports, one on each side of the block, there were blocked off. I thought that would be where it goes, but I ended up with antifreeze all over my shoes. There is a port on top of the motor at the edge by the manifold / distrib area. I had to block that off when I primed the motor cause oil shot out the top of it and almost got me. I tried to put the sensor there, but the manifold is in the way. I dont see any other spots for a sensor to go.
It goes in that spot where the oil shot out of, next to the distributor.
The factory uses a right-angle fitting about 3" long. You can accomplish the same thing at Home Depot or wherever, with a 3" pipe nipple and a 90 elbow.
Car: 88 Camaro
Engine: 310 LG4
sweet. I thought about getting an elbow,but didnt want to be ghetto, well, anymore than I already am with this project.
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
mdtoren
Aug 16, 2015 05:45 PM
