what can be causing vibration?
Old Nov 8, 2001 | 03:50 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
I have a vibration at 3,200 - about 4,000 rpm. my mechaniac said it is comming from the rear of the car. I got this vibration from accidently putting the car in 2nd at about 80 mph. the vibration seems to be comming from the drive shaft and i can feel it a lil in the clutch. what can be causeing this. from how he described it "he has to take things apart to actually find out where it is comming from". i hope its not to bad but he is not doing this till next week on monday. so anyone have similar problems or might know what it is that is causeing this vibration?
86Z28, 350 gm motor, Borg Warner 5 speed, hurst shifter, 3.73's, Edelbrock heads and carb, Edelbrock headers and cat back 3" all the way, 2 1/2" cowl induction hood, and K&N air filter.
Old Nov 8, 2001 | 04:04 PM
gruveb's Avatar
Car: 1989 IROC-1
So the Beach Boys' "Good Vibrations" wasn't refering to something like this.
He's probably right. It could be any number of things, the only way to find out for sure is to get in there are look. The fact that it happens at a given RPM is kind of wierd since it is a stick...
Stupid questios, but are you sure it isn't the engine bogging down or something?
http://www.gruveb.com/z28
Old Nov 9, 2001 | 08:23 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
positive it only happens at that certain rpm. after that it is fine and before it it's fine. and it only happens in the lower gears. well i will find out today what it is. hope nothing to bad.
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
