Ticking noise..........injectors?
Old Nov 8, 2001 | 08:01 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
The ticking noise I'm talking about is coming from the intake area. I believe it is the injectors. It is an obvious sound. Are my injectors stopping up? Any help would be appreciated. Thanks.
Old Nov 8, 2001 | 08:04 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
If its a TBI its a good chance that its the injectors. It usually isn't too noticable though unless you've got the air cleaner and stuff off. My old injectors used to do it, but it didn't seem to affect anything, I ended up having to replace them anyways though
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 8, 2001 | 08:32 PM
slowpoke's Avatar
Car: 1987 Z28
My mistake. It is a 305 TPI.
Old Nov 8, 2001 | 08:55 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes injectors can make an audible click while running, its normal.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 9, 2001 | 12:18 PM
slowpoke's Avatar
Car: 1987 Z28
I appreciate it guys. It is nice to know this for sure.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
