Hesitation
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If you have a fuel injected engine, I would start by checking the TPS adjustment. This might be causing your problem. Hope this helps
man that sounds familiar to me too - stupid quadrajet - i got the same set up as you, and i too have that problem - occcasionally there is an infintessimle bog that i get, and only starts hauling after the secondaries start to close back
anyways, if anyone has any ideas, i'm open - the only thing i can think to do is to rebuild the carb maybe
RedLeader289
May 28, 2019 01:47 PM
