Rebuilt engine Knocking
Old Oct 6, 2005 | 10:12 AM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
well i just built my 350 a couple monthes ago and i have a few thousand miles on it. i had a rocker arm stud pull out of a head and got a new head since it was under warranty.
everything was fine for a while but now i am getting this knock. it increases with RPM. i checked the valve lash and took the pushrods out and rolled them around and none are bent. i can hear it in the headers. you can hear it at idle and more throttle means louder (until a certain point) and more often. oil pressure is 50 at start up, 20 warm idle, 25-30 driving around. temp holds fine, no mixed oil and coolant, no leaks.
any ideas?
Old Oct 6, 2005 | 10:35 AM
ede's Avatar
ede
what were your clearances?
Old Oct 6, 2005 | 10:45 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Exhaust leak tick?
Old Oct 6, 2005 | 11:15 AM
djtricia's Avatar
Car: 1986 Z-28
knock
Try pulling spark plugs wires and see if the noise gets louder. That will tell if it's a rod. Mains are a little deeper sounding. Although with the oil pressure you've got I question it being a main bearing.
Old Oct 6, 2005 | 02:05 PM
Kevs87Z28's Avatar
Engine: 355 Carb
everything was new. mains werent oversized. rods, and crank were brand new.
could be exhaust tick but its more of a knock.
i'll try the plug wire idea and see what comes of it.
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
