Is it possible to convert
Old Nov 9, 2001 | 09:43 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Can I change a externaly mounted fuel pump gastank too having one internally mounted.The reason that I ask this is I desperatly need a new tank,first it leaks and the filler neck got bent by the last owner"they left the gas station with the pump still in" ,cant keep the tank above 1/4 full or gas comes out of the filler neck.My car is a 85 2.8 mpfi, the donor tank came from an 82-84 Z28.It has two connectors to go the the fuel gauge.The one in my car has 3. Any help would be appreaciated.
Old Nov 10, 2001 | 03:16 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
That's a tough question. I would see if I could find a wiring diagram for each car and see what the difference is between the two. Then fabricate whatever wiring you need.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
[This message has been edited by J's86ROC (edited November 10, 2001).]
Old Nov 10, 2001 | 05:34 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Why not just swap your sending unit/fuel pick up assembly onto the new tank and remove the other when you do the "R 'n R"
The tanks should be the same otherwise.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
