cooling fans
Old Oct 6, 2005 | 06:29 PM
mrdezman's Avatar
Car: 89 iroc/ 88 supra targa top
Engine: 350 tpi / 7mge
Transmission: 700r /
cooling fans
will removing the cooling fans fuse cause the fans to run constantly.
Old Oct 6, 2005 | 06:33 PM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
i dont think they will run at all...
Old Oct 6, 2005 | 07:02 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
As long as the key is on, they'll run constantly if the grounds are pemanently connected to ground. Check your fan temp switch connector and try unplugging it. It should be located in the passenger side head between cylinders 6 and 8. My switch was broken and defaulted to an always-on condition. I ended up eliminating the switch myself. I still have the wire around somewhere in case I decide to put a manual fan switch in, but as it is now, I don't have it. I run both fans off of the ECM.
Old Oct 6, 2005 | 07:08 PM
ncgator's Avatar
Car: '89 Trans Am
so wats the point of the fuse?
Old Oct 6, 2005 | 07:31 PM
Car: 1997 Corvette
I was assuming that the fuse was in working condition, if there is one. I don't remember, I haven't worked on my car in a while since I've been away at school
I know theres a C/H Fan Fuse I believe, but that's for the blower motor.
Old Oct 9, 2005 | 10:08 AM
mrdezman's Avatar
cooling fans
THANKS FOR YOUR REPILIES ABOUT THE FANS. I WAS CONCERNED BECAUSE I JUST PURCHASED A NEW 305 TPI FOR MY IROC. THE 350 WAS ON ITS LAST LEG. ALSO, IT DIDN'T RUN ALL THAT GOOD BECAUSE I WAS USING THE 305 SETUP. (COMPUTER, INJECTORS)
WELL, I WAS TRYING TO STAY WITH THE 305 TPI BECAUSE I'LL MAINLY DRIVE TO AND FROM WORK IN THIS AUTO. WELL, WHEN I WENT TO PICK UP MY GAL, BEING MY IROC, HER FANS WERE RUNNING CONSTANTLY AND ALSO, MY FUEL GAGE AND OIL PRESSURE GAUGE WERE NOT WORKING. SO, I JUST WANTED SOME AMMO JUST IN CASE THE REPAIR SHOP STARTED SHOOTING OFF HIS MOUTH ABOUT IT BEING THIS AND I CAN SHOOT BACK AND SAY IT PROBABLY THAT. YA' FEEL ME. BY THE WAY, THIS PROJECT PUT ME BACK 3 BIG ONES AND I ALMOST COUGHED UP 2 LITTLE ONES . SOME BODY HIT ME BACK! ( E MAIL)
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
