need help setting timing
Old Oct 8, 2005 | 09:45 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i've got some pretty extensive mods, and i thought modded motors were supposed to be able to run 10-12 degrees of advance without any trouble. my car seems to run alright like this, but a bit of white smoke comes out of the exhaust. not thick or anything, just hazy, like if its cold out.
i back it off to about 6 advanced and it doesnt do it anymore.
i also have a bit of gas dripping out of my pipes, couple drops a minute. i would think id want to turn down the fuel pressure, but its already only at 40.
im still learning about tuning, any tips are greatly appreciated.
Old Oct 8, 2005 | 09:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I doubt it's gas dripping out your tailpipe. If it was, you'd be blowing your mufflers off. Normally what drips out the tailpipe is water. It's a byproduct of combustion.
Timing is more than just base timing. Increasing the base timing also increases the total timing. If total timing runs best at 32* and you bump the base timing up 6 more then the total timing is now 38* and you could be losing power because of that.
Old Oct 8, 2005 | 10:22 PM
1meanGTA's Avatar
but what causes the white haze? if its hot out i only see it on startup or if the engine is idling really low and stumbles a bit. today it was about 60 degrees and raining out and it was doing it as it idled normally.
it did this whether at base or total timing.
any recommendations for a fuel pressure setting with my mods? im running a 10:1 ratio. mod list is in sig.
i guess i just want tips on how to get my car running the best it can.
Old Oct 8, 2005 | 11:18 PM
1meanGTA's Avatar
is the smoke just condensation? its definitely white and not blue. will the engine run healthier if i leave it at 6 base with no smoke or does it matter?
is there any way i can check my computer for knocks without a laptop?
Old Oct 9, 2005 | 10:49 AM
1meanGTA's Avatar
cmon yall i need some help here. todays my last day off this week, and i've got nothing to do
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
