Knock and tick
Old Sep 26, 2005 | 01:23 AM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
Knock and tick
I've got what sounds like a loose rocker tick at idle,and as I bring the rpm's up, I'm getting a soft hollow knocking sound.
I've pulled the valve covers and checked the studs,lash and oil flow,all seems ok. Oil pressure is great(35-40psi warm/idle 60+ off idle) I first thought flex plate so I was going to do a shift kit anyway I pulled the trans put in a new sfi plate and new converter. Still there.
The tick is constant. The knock I can't hear at idle. Bring up the rpm's it's there.It dosn't really get louder but does increase with speed,parked or driving.
Thinking rod/main bearing???
Any tips would be very much appreciated.
Old Oct 1, 2005 | 08:38 AM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
That sounds like what it might be. It will probably get progressively worse as you drive it. Good luck.
Old Oct 1, 2005 | 11:52 PM
That's what I'm afraid of. Guess we'll find out this week when I yank it out . Stopped driving as soon as I heard it.Hopefully the damage is minimal.
Old Oct 2, 2005 | 01:18 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
My first guess when the knock gets louder with RPMs is a rod/main bearing. May as well replace them as you can get a complete set for around $50.
Check your clearances you may need to go with some bigger bearings though.
Old Oct 2, 2005 | 11:51 AM
sellmanb's Avatar
Car: '86 Berlinetta
Who wants to bet it's an exhaust leaked coupled by pinging caused by the exhaust leak?
Old Oct 2, 2005 | 12:00 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Knock and tick
Originally posted by Snake Oiler.The tick is constant. The knock I can't hear at idle. Bring up the rpm's it's there.It dosn't really get louder but does increase with speed,parked or driving. Thinking rod/main bearing???
Whoooaa now...., just because a knock becomes prevalent, does not necessarily mean it's a bearing. Does the knock have a steady rhythm, or is it sporadic? Does it sound metallic? It could be somewhere in you're ignition.
As for the ticking, it's definitely valve lash.... as that's the by-product of such a heavy foot.
Old Oct 2, 2005 | 01:09 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
man we are having the same bad luck
Old Oct 3, 2005 | 08:51 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Re: Re: Knock and tick
Yep, I agree, I had a slight tick that I thought was a lifter on a new motor and ended up being a exhaust leak at the header. My tick however, only was noticable when the car was first started and went away after the car was warmed, I guess the gasket swells and seals the leak. I havent fixed it yet!
Old Oct 7, 2005 | 10:32 PM
Got it out and apart today
#1 rod bearing shifted and copper.2 other rods copper,but not shifted.
mains all were fine.
Cylinders all looked fine.
Gonna pull the cam tomorrow and check those bearings.
I bought this short block used,('93) and was in similar shape when I took it apart then(almost a year ago).
I had the block reworked,crank redone,rods checked etc...
Now ,3500 miles later, i'm back where I started.
Starting to wonder if there is a problem with the crank and/or the oil passages.
Old Oct 7, 2005 | 10:36 PM
sellmanb's Avatar
Car: '86 Berlinetta
it is possible that the crank is out of round, or the wrong rod caps went back on, or an oil hole is plugged up.
Basically, if you find that there's metal missing, then it's gone somewhere and I wouldnt expect your oil filter to catch it.
Expect it to be circulating in the motor still. I'd take it all apart and have it hot tanked. Then have it align bored, and make sure that the crank is still in-round.
Old Oct 7, 2005 | 11:47 PM
When I had the machine work done, they(supposedly) checked that and balanced the rotating assembly with the flex plate and dampner. I would think they would have found any problems then. Thinking bout woriking some OT and just getting a new short block. Or maybe a new crank and rods. Still PO'd about this whole thing.
Thought I read another thread where they said somethig about defective(quality control) bearings. Don't remember what brand though.?
Old Oct 8, 2005 | 11:14 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
383 time
lol sorry bout your luck man. i had similar sounds but turned out to just be a blown header gasket.
Old Oct 8, 2005 | 08:54 PM
sellmanb's Avatar
Car: '86 Berlinetta
the quality control thing was Clevite.
Use Federal Mogul if in doubt
Old Oct 8, 2005 | 09:33 PM
Clevites are what I put in. Wonder if I got a bad set?Now I have to decide what to do.Maybe a new crank and rods would be the easiest?Or should I have the old ond reground to 20 under and the rods checked?
Old Oct 9, 2005 | 11:21 AM
sellmanb's Avatar
Car: '86 Berlinetta
If it only started to knock and tick, then I would just have everything inspected. There's a possibility that nothing other than the bearings got hurt.
To be safe you should take the motor out (I know, a pain ) and dissassemble it. Take all pieces you can to the machine shop for hot tank and magnafluxing just incase.
Then have the crank inspected, and make sure to put in new cam bearings too.
If you only need it ground on one or two lobes then it may be a cheaper "rebuild" than you think. You could probably get away with leaving the rods and pistons in their bores too so you dont have to rehone them.
Probably looking at around 400 dollars when it's all said and done (assuming you dont need new rods and crank)
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
