TPS Adjustment Question-Ford TB on Thirdgen
Old Oct 8, 2005 | 05:20 PM
LT1guy's Avatar
Car: 1987 Trans Am
Using a GM ECM...what should the TPS (Ford) on an Accufab throttle body be adjusted to? The GM setting or the Ford setting? If its the Ford setting, what are they? I don't have my Ford 5.0 manual available right now. Thanks a lot!
Old Oct 8, 2005 | 08:46 PM
Vader's Avatar
The ECM/PCM is Delco. It's going to be expecting the same kind of inputs as any other Delco ECM. Set it at 0.54V at the closed throttle position.
Old Oct 8, 2005 | 09:31 PM
LT1guy's Avatar
Car: 1987 Trans Am
Thanks Vader, I figured you'd be the one to answer!
Old Oct 9, 2005 | 12:23 PM
LT1guy's Avatar
Car: 1987 Trans Am
Ok, I slotted the Ford TPS to get more adjustment and have the low side setting at .54 volts. The problem now is that the WOT reading is only about 4.05 volts, not the 4.5 volts it was before. I'm thinking there is no way to get the proper adjustment out of the Ford TPS, since its range is approximately 3.5 volts and the GM is 4 volts. I may look into using the GM TPS after all...not sure what to do.
Frozer!!!
Jan 19, 2024 04:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
