higher ratio rocker arms
Old Oct 6, 2005 | 08:12 PM
DTM 91 Z28's Avatar
Car: Camaro
ive been lookin into putting some higher ratio rocker arms on the 305 TPI. What is the stock ratio? What would you guys recommend? Will i see a big difference in gas milage? Do i need new valve springs? If youve done this, tell me how
thanks!
Old Oct 6, 2005 | 10:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
do a search.
in short, you won't see much gains if that's your only mod. you shouldn't need new valve springs.
how many kms on the car?
you may want to do the valve seals at the same time though.
stock is 1.5, you could get 1.6, but you won't see anything dramatic.
Old Oct 6, 2005 | 10:20 PM
DTM 91 Z28's Avatar
Car: Camaro
80k miles...headers and 3 inch catback
it smokes black for about 1-2 seconds upon start up which is typical of GM valve seals....how hard is it to replace valve seals? It may not be worth it since they dont leak too bad
damn o rings! lol
Old Oct 6, 2005 | 10:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
well if you're in replacing the rockers, then it's pretty close to doing the seals. not too bad, either the rope trick or compressed air will hold the valves up while you change the seals. and they're pretty cheap in the grand scheme of things, you'll earn that money back in less oil you add to the car really fast.
that's low miles, your stock springs are probably ok. I'd look at a cam, or something that'll give more bang for the buck.... not a TPI guru here, so i'll let someone else chime in.
Old Oct 6, 2005 | 10:36 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Black smoke is by no means typical of valve seals. Leaky injectors maybe, but certainly not valve seals.
Old Oct 6, 2005 | 10:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
black smoke, blue smoke, meh, same difference.
Old Oct 7, 2005 | 12:06 AM
DTM 91 Z28's Avatar
Car: Camaro
yeah i meant to say blue smoke
i dont want to put in a cam unless im pulling and rebuiliding the engine
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
