Valve seal/inner valve spring ?
Old Oct 7, 2005 | 04:08 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I just started replacing valve springs and seals on my heads and I have a question about a clearance issue. The seals are the Viton rubber positive stop type and the springs are Comp cams 987's. The inner valve spring seems to be very tight against the seal and I was wondering if that would be a problem? The seals are the right fit for the guide and stem diameters so I don't think that is a problem. I really have to force the spring over the seal to get it on. I don't know if that would be a problem or not, so hopefully some folks with experience can help me out.
Old Oct 7, 2005 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like you need seals with a narrower O.D. to clear your springs.
Old Oct 7, 2005 | 05:37 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
werd. You don't want them touching.
Old Oct 7, 2005 | 06:02 PM
Car: 1986 Iroc
Engine: Afr 408
Yea, I guess that's kinda what I thought. Thanks guys. Well I guess the next question would be for the people that have used 987's. Which positive stop seal did you use?
Old Oct 7, 2005 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I used Comp 503 seals with my 987s.
Old Oct 7, 2005 | 07:38 PM
Dialed_In's Avatar
I've got a box of K-Line seals that I use on most everything. I can send you a set if you want.
Old Oct 14, 2005 | 02:36 PM
Car: 1986 Iroc
Engine: Afr 408
Thanks guys, I used the 503's and they all fit fine. Except....I kinda broke one,
Does anyone have one extra 503 laying around they don't need? I feel like a moron. I'll probably end up buying another pack, oh well.
Old Oct 14, 2005 | 03:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Order a Comp 503 for a single seal instead of 503-16 for a whole package of 16.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
