car running like s@#t
Old Nov 9, 2001 | 08:44 PM
leroy49's Avatar
Whenever I first start my car up it starts to sputter and die, and for the first mile driving it feels real jerky like it is not getting any fuel. this was a problem last year but after change the plugs, wires, cap, and rotor it went away, but 6 months ago it started back up again. I have changed everything but the wires and it still does it. Any help please.
1991 305 tbi
Old Nov 9, 2001 | 09:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Welcome aboard,
I would check the condition of your wires to make sure none of them are burnt, I have had 3 lay on the headers and crack thru, then I discovered the wonders of wire looms. Check to make sure you don't have any vacuum leaks, but I doubt that could be the problem since you say it goes away. Also check to make sure your cat isn't clogged. Also check to make sure the TC lockup is working properly.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 10, 2001 | 08:17 PM
Faught's Avatar
Ya check your vacuum lines. I had a problem with the line going from the PCV valve going behind the TB...On the far end it was cracked and sometimes it shifted enough to open the crack more and caused the car to idle real low.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
