Heater question
Old Oct 7, 2005 | 08:46 PM
92Forumla's Avatar
Car: 2017 2.0T Camaro / 1989 IROC
Engine: LTG / L98
Transmission: Tremec TR 3060 / 700R-4
Heater question
I have a 1992 Firebird 305 TBI and for some reason the heater doesnt work. Also for some reason after a rainstorm the underpart of my dash is wet leaking onto my passenger floor. I cannot find a visible place where the leak is coming from, I realize this is very vague but I need some help.
Old Oct 7, 2005 | 11:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is it anti-freeze smell or rain water smell? Could be the same problem, could be completely un-related.
In anycase, proper flow to the heater core needs to be established (if it isn't coolant smelling). Make sure theres warm fluid to the heater core, past the diverter valve. HC could also be blocked. Try flushing it.
Old Oct 8, 2005 | 01:50 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
This is most likely the same problem as many people have. My first and most likely best recommendation is to change the heater control/diverter valve. I'd bet this is your problem. It's easy to find, look like a mushroom with 2 or 3 hoses coming out of it, on the passenger side of the engine, up top. It's most likely frozen shut. 15 bucks and you're good to go most likely. As for the leak, prolly the same as my other problem. A firewall/cowl leak somewhere. Prolly a bad seal around some opening/cable hole/something in there. I'm gonna have a looksee on mine this weekend on the drivers side.
Old Oct 8, 2005 | 10:14 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: Heater question
Originally posted by 92Forumla
I have a 1992 Firebird 305 TBI... Also for some reason after a rainstorm the underpart of my dash is wet leaking onto my passenger floor. I cannot find a visible place where the leak is coming from, I realize this is very vague but I need some help.
check the firewall panel under your windshield. there is sealant there that could be all dried up and cracked and now has holes in it. probably need to clean that all out and put new sealant in there.
Old Oct 29, 2005 | 04:08 AM
TheBeastInBlue's Avatar
Car: 1988 Camaro Custom
Engine: Blown 383
Re: Heater question
yea and when hes says leaking into the floor he meens it. there was a ****in puddle.lol
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
1985chevydude
Aug 22, 2015 05:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
