zz302 build up? Questions comments inside.
Old Nov 11, 2001 | 03:24 PM
spitfire350's Avatar
im consitering building a 302 chevy, 350 block and a 283 crank = 4in bore ad 3in stroke. but the prob is, ater there large journal 283 cranks for my large journal block? this is the only problem i can see. anyhelp wouldbe great.
keep the stang's far behind u and the cops even farther
Old Nov 11, 2001 | 03:36 PM
ede's Avatar
ede
find a SJ 327 block, if you want 4 bolt mains have splayed caps installed, or buy a 3" crank for the LJ block. not sure if it'd work or be possiable but you might find soemoen that could weld the crank up and turn it to the correct size for a LJ block.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
