ALDL question
Old Oct 8, 2005 | 02:06 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
ALDL question
Those who have a painless wiring harness. What route did you hook the ALDL up to? I mean... Did you cut a hole in the firewall? Or, did you just run it from where the computer is.
Old Oct 9, 2005 | 01:15 PM
Vader's Avatar
The only Painless harness I've worked on had plenty of wire to mount the ALDL almost anywhere (about an extra 5' or more). Mounting it in a "conventional location like near the fuse panel under the dash is relatively easy. I would hesitate to mount it under the hood like Ford did on some of the EEC systems, since the connector is exposed to contamination, heat, and chemicals that can screw it over.
Old Oct 9, 2005 | 03:35 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Another vote for keeping it under the dash.
Its a total pain in the **** trying to connect a scanner to a connector thats been left out in the elements for a while. Esepcially like on the f150's ive worked on they are usually packed full of dryed out mud and whatnot.
Old Oct 9, 2005 | 10:53 PM
Vader's Avatar
Originally posted by 84z28350
...the f150's ive worked on they are usually packed full of dryed out mud and whatnot.
That's exactly what I'm talking about. Sticking the meter probes in there for a code reading is no treat when it's been full of crud.
Old Oct 10, 2005 | 01:57 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have my ALDL hookup running from the diagnostic port to under the ashtray. So when I want to log some data, I just pull out the ashtray and pull out the serial cable. Put it all back when I am done. Stealthy and handy.
chazman
Aug 28, 2018 03:25 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
mike_c
Aug 27, 2015 04:32 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
