i cant read the numbers on my timing marks
Old Oct 9, 2005 | 04:19 PM
package's Avatar
Car: 1987 camaro lt
Engine: 305 4 barrel
Transmission: th 700r4
can anyone tell me the corespong numbers for the timing marks on a 87 camaro 305 carburated.i cant get a wire brush down to clean them off cause of the air conditioning compressor.what is the recomended timing for a 305?
Old Oct 9, 2005 | 05:08 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It will say on the emissions sticker what to put the timing at, and if your still using an ECM make sure you unplug the connector going to the dizzy.
Old Oct 9, 2005 | 05:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Factory on my Crapiece was 0° (LG4). I bumped it to 6° advance when I gave it a tune up. Ran a little happier.
As stated, be sure to disconnect the 4 wire weatherpack that runs off the rear of the distributors base to disconnect the EST system.
Old Oct 9, 2005 | 06:19 PM
package's Avatar
Car: 1987 camaro lt
i cant read the numbers on the marks to tell the degrees do you have a diagram or can you exkain them.
Old Oct 9, 2005 | 07:11 PM
llvll4l2c91350's Avatar
0 will be in the middle. then on each side it will go 4, 8, 12 before and 4, 8, 12 after (TDC). there will be a line between each #.
i have mine set at 6* BTDC (line between 4 and 8).
Old Oct 9, 2005 | 07:35 PM
package's Avatar
Car: 1987 camaro lt
if im not mistaken is towards the passenger side before tdc
Old Oct 9, 2005 | 07:45 PM
yup
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Steve78LT
Feb 24, 2016 12:15 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Thirim
Aug 9, 2015 06:19 PM
